In Anima you can import your own models in FBX format, either Static or Rigged, and use them to populate your scenes.
The static models cannot be animated by Anima because they don’t have a bone structure, but the advantage of adding them to the Anima library is that once imported, you can use them through the Drag & Drop Gallery panelthrough Anima Drop directly inside your 3D application thanks to the Anima plugins for 3ds Max, Maya, Cinema 4D, and Unreal Engine. Take a look at the video tutorial available here to see how fast and easy it is to use this panel.
