The installer automatically updates Corona to the newer version if it detects an older version. If you need to manually uninstall Corona, please make sure that 3ds Max or Corona components, such as the Corona Image Editor, are not being used.
Uninstalling Corona
The
uninstaller originally resides as an Uninstall Chaos Corona for 3ds Max shortcut in the following location
Code Block
languageplain
C:\Program Files\Chaos\Corona\Corona Renderer for 3ds Max\
uninstall
UI Text Box
colorlight-cyan
iconinfo
In older versions of Corona, the location is:
C:\Program Files\Corona\Corona Renderer for 3ds Max\Uninstaller
UI Text Box
typeinfo
You can also use the Windows "Add or remove programs" utility to uninstall Corona.
After the uninstallation is complete, there may be some leftover files that you need to delete manually. Please check if the following folders are present and delete them:
Fancy Bullets
typecircle
  • %programfiles%\Corona
  • %programfiles%\Chaos\Corona
  • %localappdata%\Autodesk\3dsMax\20xx - 64bit\ENU\en-US\plugcfg\corona
  • %programfiles%\Autodesk\3ds Max 2024\Plugins\ (Delete only corona-related files from here if present)
