UI Text Box
typeinfo
You can also use the Windows "Add or remove programs" utility to uninstall Corona.
Command Line Parameters
ParameterDescription
-h or --helpDisplays command line help.
-n or --noGuiRuns the uninstallation in console mode with no user input (no confirmation prompt). In this mode, the uninstaller is not able to delete itself, so
the fileC:\Program Files\Corona\Corona Renderer for 3ds Max\Uninstaller\RemoveCoronaForMax.exe is left on disk after the uninstallation is finished.
UI Text Box
typenote
Console mode may not work as expected when run directly from the Windows command line console. In such a case, the console will does not wait for the uninstaller to finish and will display displays a new prompt. It will also capture captures and accept accepts user input while the uninstaller is running and printing into the console.
Solution: The issue will does not appear occur when using a .bat file or any other script, which is the intended use case. In this caseThen, the script correctly waits for the uninstaller to finish before proceeding.
Fancy Bullets
typecircle
  • %programfiles%\Corona
  • %programfiles%\Chaos\Corona
  • %localappdata%\Autodesk\3dsMax\20xx - 64bit\ENU\en-US\plugcfg\corona
  • %programfiles%\Autodesk\3ds Max 2024\Plugins\ (Delete only corona-related files from here, if present)
