Once you've installed Corona for 3ds Max, you need to activate it. The process varies slightly depending on the Corona version you are activating:
Tabs Container
directionhorizontal
Tabs Page
titleCorona 12, Update 2 and later
UI Steps
sizesmall
UI Step
Start 3ds Max.
UI Step
width60%
Go to Render Setup > Renderer and set Corona as your active renderer.
width5%
width35%
Image Modified
UI Step
width60%
If you are not logged into your Chaos account, a notification
popups
pops up prompting you to sign
into your account
in.
Click Sign in.
width5%
width35%
Image Modified
UI Step
width60%
Sign in with your Chaos email
address
and password.
If you have an active Corona subscription, you are done - your license is now activated! You can just return to 3ds Max and start rendering right away.
width5%
width35%
Image Modified
UI Step
width60%
To access the License Server or your Chaos account, go to Render Setup > System > About Chaos Corona/Licensing and select Open license server for access to the Chaos License Server, or Chaos account for access to your account.
width5%
width35%
Image Modified
UI Text Box
typeinfo
For Corona Premium
 license
license, and to download the other Chaos Products included (Chaos Phoenix, Chaos Scans, Chaos Player), please visit the Chaos Downloads Page.
UI Text Box
typetip
If you need any help activating Corona or any other product, please contact us
Tabs Page
titleCorona 12, Update 1 and previous
UI Steps
sizesmall
UI Step
Start 3ds Max.
UI Step
width60%
width5%
width35%
Image Added
UI Step
width60%
In the Render Setup window, go to System > About Chaos Corona/Licensing.
Click Activate license.... A window with multiple options opens.
width5%
width35%
Image Added
UI Step
width60%
Click Open the License Server.
width5%
width35%
Image Added
UI Step
width60%
The Chaos Licensing page opens in your internet browser. Click Sign in.
width5%
width35%
Image Added
UI Step
width60%
Sign in with your Chaos email address and password.
width5%
width35%
Image Added
UI Text Box
typeinfo
For Corona Premium license, and to download the other Chaos Products included (Chaos Phoenix, Chaos Scans, Chaos Player), visit the Chaos Downloads Page.
UI Text Box
typetip
