You can change the telemetry settings directly in Cinema 4D at any time after installing Corona. The Usage Data settings can be found in the Preferences window > Renderer > Corona. You can access the Corona Renderer Preferences through the Corona menu > Preferences. Alternatively, you can access the Preferences through the Edit menu > Preferences.
width45%
Send Product usage data Launches the Chaos Improvement Program for Corona upon restarting Cinema 4D.When you click on the field, it opens the Chaos Telemetry window.
When you open the dropdown menu, you can see some additional options:
Adjust shader data... – Opens the Chaos Telemetry About Product usage data – Opens the Product usage data window, where information about the telemetry program is displayed.
Save message preview to filepreview of collected data... – Saves the telemetry data onto a specified .txt file.
width10%
width45%
This window allows you to change your telemetry settings. When you are done, click Confirm to apply your choices.
Learn More... – Read more onlineOpens the Chaos Privacy policy at https://www.chaos.com/privacy
width5%
width40%
Image RemovedImage Added
Product Usage Data
width10%
width40%
Image Added
Chaos Telemetry
Image Removed
Product Usage Data window
width10%
