UI Text Box | ||||
In older versions of Corona, the location is: C:\Program Files\Corona\Corona Renderer for 3ds Max\Uninstaller |
UI Text Box | ||||
You can also use the Windows "Add or remove programs" utility to uninstall Corona. |
Command Line Parameters
Parameter | Description |
-h or --help | Displays command line help. |
-n or --noGui | Runs the uninstallation in console mode with no user input (no confirmation prompt). In this mode, the uninstaller is not able to delete itself, so the fileC:\Program Files\Corona\Corona Renderer for 3ds Max\Uninstaller\RemoveCoronaForMax.exe is left on disk after the uninstallation is finished. |
