Section | |||||||||||||||
- New AI Enhancer icon
Fixed Bugs
- Closing the CAD during Multi-Asset Placement leads to Infinite Error Loop when you Choose to Apply and Leave: Error dialog is displayed only onceand then Enscape quits.
- Enscape Version Is Shown On Loading Screen With Customized Background Image: Enscape version is no longer visible on Customized Background images
- Invalid License Overlay Not Refreshing on New License Error: No valid license overlay is displayed.
- Section plane is not applied after you edit it once: Section planes are now updated correctly.
- Enscape can't start with specific window restore data: Enscape now starts properly.
- Meshlets can be passed to MapletMaintainer despite unwrapping failure: No crashes or quality regressions observed
Unable to place an asset right after rotating around a model/surface (even if the camera has stopped)
- Ray-Traced Sun Shadows Offset in Polystyrol Mode with Orthographic Camera: Shadows now appear correctly aligned.
- ReSTIR Capture Results Are Not Deterministic: Still image captures of the same camera position with the same settings now generate 100% deterministic/reproducible results on the same machine.
- ReSTIR: Checkerboarding artifacts
- ReSTIR: Logs throw "Exceeded slot index for Buffer" when resizing rectangle lights: No artifacts and crashes observed now.
- Video textures skewed due to incorrect row alignment: Video textures are now rendered properly.
- Renderer crashes for user paths containing multibyte characters: Renderer starts without crashing.
Enscape 4.5.0 Is Not Detected By New Version Check: New versions are now correctly detected.
- [SketchUp] Document Isn't Properly Closed On Shutdown Leading to Log Spam: The exception on shutdown does not appear anymore in the SketchUp plugin logs.
[SketchUp] Time of Day Resets When Creating a New View: The time of day remains the same after creating a new view.
- [SketchUp] Material Editor albedo colors are incorrect after switching document: Material Editor albedo colours now accurately reflect the selected material after switching document.
[SketchUp][Enscape Impact] Performance map visualization does not respect sections: Performance map is now aligned with section planes.
- [Vectorworks] Inconsistent global illumination: Resolved an issue where Global Illumination (GI) results varied between batch renders of the same views within the same session when using Hardware Ray-Tracing (HWRT) and Real-Time Sun and Sky (RTSS) in Vectorworks. GI is now stable and consistent across consecutive batch exports.
- [Rhino] Cutout texture rotation does not reflect on the renderer when the mapping type is Worldplane/worldbox for Albedo: Cutout texture rotation now reflects on the renderer.
- [Rhino] When Deleting an Asset Definition It Will Not Be Added Again: Adding Enscape assets to Rhino is now a consistent behavior, if an asset is added for which a block definition does not exist a new one is created.
[ArchiCAD] Parallel Light Export Error in Enscape 4.5: The light works as it did before
Known Issues
Color disappears when Intensity value changes. The emissive material resets its color to white as soon as you close the material editor.
