ErrorDescription
-98
There are no available licenses for this V-Ray version on this account.
-96The online license server is disabled.
-197The license server version is not the correct one for the Chaos product.
-199There is no IP address pointed to the license server. Check the Change license settings window for empty fields.
Error 1002All licenses are in use, and there are no available licenses of this type.
-7The license server is installed, but you are not logged in.
-2 The firewall blocks the 30304 port.
-200The License Server could not be reached.
-198
All the licenses for this product are currently engaged.
10061
No access to the V-Ray license server.
111
Could not connect to a working license server.
61
1004
Active sessions limit reached. All licenses for this product are currently engaged. You need to release any of the other engaged devices to be able to use the license on this device.
1005
Could not obtain license. Sing in to you Chaos account to continue.
Resolution Checklist
If you encounter any of the Common Errors, please see the possible resolutions for your OS:
