Progress Bar Container
step2
Progress Bar - Hyperlink Step
titleStep 1: Install V-Ray
url Installation
titleStep 2: Activate your license
urlChaos License Quick Start Guide
titleStep 3: Load V-Ray in Maya
urlV-Ray Configuration
Multiexcerpt
MultiExcerptNameLicense Start
Activate the License
The Chaos License Server is the bridge between the Chaos Product and the Chaos Account associated with a given license. You cannot use any Chaos product without a license.
You connect to the License Server by installing the license application locally on your machine or connecting to a machine in your local network that has a shared Premium license set up.
If you are hosting a Premium Chaos License Server for multiple machines, please see
the Administrator Workflow.
Please follow the instructions for your subscription plan:
Solo and Cloud-Based Floating Licenses
width45%
If you have a Chaos Solo license plan or are connected to a Cloud-Based Floating License, follow these steps
Panel
borderColordarkgrey
titleColorwhite
titleBGColordarkgrey
borderStylesolid
titleSolo License
The Solo License requires the server to be installed directly on your machine. The Solo License can only be used by a single user with a user login.
Fancy Bullets
typecircle
  • Download your Chaos product(s). Open the installation wizard and follow through with a basic installation setupDuring the default installation, the license application is installed locally on your machine. For more information on the specifics of the installation, go to the Installation page of your chosen product.
  • After the installation is complete, you will be redirected to the Chaos License Server's Interface. If you are not signed into a Chaos account, go to the Online licensing dropdown menu and select Sign in.
Image Removed
Fancy Bullets
typecircle
  • You are then prompted to enter your username/email and password.
  • Once the activation is successful, you will be able to see the list of your available licenses on the Chaos License Server home page.
UI Text Box
typenote
If you accidentally close the window, you can type 127.0.0.1:30304 / localhost:30304 in a web browser. Keep in mind that you cannot use any Chaos products without an active license!
  • Open Maya and go to V-Ray menu > Licensing > Chaos Account.
  • Select Sign in from this dialog and enter your Chaos account credentials on the Chaos accounts Sign in webpage.
width5%
width50%
Image Added
width45%
If you don't sign in first, and attempt to render with V-Ray, you are prompted to verify your license by singing in.
width5%
width50%
Image Added
Premium or Network Floating Licenses
width45%
Panel
borderColordarkgrey
titleColorwhite
borderStylesolid
titlePremium License
The Premium License can be shared between multiple users and devices, or it can be used locally - similar to the Solo License. If you only plan to use the license on your machine, see the Solo License section.
When doing a shared setup for a Premium license, the license holder needs to install the license locally on at least one machine in the network. Installing the license happens automatically when you perform a default Chaos product installation. If you only need to install the License Server application separately, see the Installation page. This machine can use the license, but it also serves as a connection point for others to connect to the license. If you are the license holder, i.e., the administrator, see the Administrator Workflow page.
Here is how to connect to an already set-up Premium shared license:
section
Fancy Bullets
typecircle
  • The administrator needs to give you their machine's IP address. This serves as your connection point to the Chaos License.
  • When installing your Chaos product, at the Licensing step, select Remote. In the Primary License Server field, type the server IP address that your license administrator gave you. At the end, add the :30304 port.
  • Continue to finish the installation. You are connected to the active licenses after that.
25%
width
5%
width50%
Image Modified
Example screenshot
width25%
Fancy Bullets
typecircle
Borrow Licenses for Offline Use
You can also 'borrow' a license to use offline on a machine with unstable or with no internet access. For more information, see the Borrowing Licenses for Offline Use page.
Troubleshooting
If you are experiencing any difficulty installing or running the Chaos License Server, please refer to the Troubleshooting page for possible solutions.
Panel
borderColorred
borderStylesolid
Visit the License Server section of the documentation for further details on the Chaos License Server, such as how to check your license expiration and status, how to access various settings, and more advanced options.
Next Step
Go to step 3 to see how to load V-Ray in Maya.
