This page provides information about the command-line or silent installation of Anima.
OverviewOverview
A silent installation allows you to a complete Anima installation to be performed without any user input during the process, using either the default options or, if desired, a predefined set of options. To set up a silent installation, follow the instructions below.
Run the installation The simplest way to setup a silent installation is to run the installer file from the command prompt with the the -gui=0 argument:
anima_installer_6.0.0.exe -gui=0
Follow the instructions of the installer and set up the installation the way you want to have it on all machines. This creates a file named config.xml in the folder of the installation file.
Run the installer with the following command:
anima_installer_6.0.0.exe -gui=0 -configFile="xml_file.xml" -quiet=1
The -quiet=1 argument causes the installer to read the variable values from the .xml file and perform the installation without user input. It also accepts the EULA and Global Consumer Privacy Policy. If you do not specify the -quiet=1 option, the installer will ask for a confirmation of each variable before proceeding.
UI Text Box
colorlight-yellow
iconwarning
typenote
By using the Chaos installer for automatic installation with the respective options for that (-auto or -quiet=1), or otherwise installing a Chaos product, you accept the Chaos End User License Agreement and the Chaos Global Consumer Privacy Policy.
Usage
The installer can be executed with both visual and non-visual options.
Arguments
argument. This option forces the installer to run without a user interface, so no visual dialog shows and all the interactions happen through the console.
After that, answer the questions on the console when they come up. Then, the installation continues applying the default options, and a config.xml file is created. Inspect the XML file with a text editor and modify the options listed there to adapt them to your needs.
For example, using the command below, the only questions asked is to accept the EULA and GCPP:
Code Block
languagebash
anima_installer_6_1_0_baa9803d70.exe -gui=0
A config.xml file is created in the same folder where the installer is placed. Open that config.xml file with your preferred text editor, and modify any of the values listed there (refer to the details below to learn more about all the values).
Once the config.xml file is customized, use the -configFile option to force the installer to use the values specified:
Code Block
languagebash
anima_installer_6_1_0_baa9803d70.exe -configFile="config.xml"
Arguments
The following table contains a list of arguments and a description of the different values. When an argument has a possible value The values that may be used for each argument are described in < > brackets. When an argument has possible values of 0 or 1, the values should be considered as 1 = true and 0 = false.
Specifies path to an installation configuration file automatic installation is without user input Installation requires user input and asks for a confirmation of each variable before proceeding. It also prints log
-debug
Specifies the level of debug logging by the installer [0-3]. Defaults to 0 and assumes a value of 1, if argument is provided with no value. Then, it creates a log file of the installation in the Temp folder of the current user.
Sample path: C:\Users\<your_user_here>\AppData\Local\Temp\installer_debug_AAAA_MM_DD_hh_mm_ss.log
-gui
Specifies if a Graphic User Interface or a command line one is used during installation:. Defaults to 1.
0 – No Graphic User Interface is visible, installation is in so all the interactions happen through the command line.
1 – Installation is with a A Graphic User Interface .
-configFile
is provided and the user can easily select the installation options.
-quiet
Specifies whether the
output of all the actions performed by the installer should be shown or not. Defaults to 1, which means that the "quiet" option is enabled, so the output info is minimal.
0 –
Disabled, all the actions are shown in the console.
1 – Enabled, most actions are hidden from the console.
-configFile
Specifies a path to an installation configuration file (i.e. "config.xml"). When used a -gui=0 argument is applied automatically, so no UI is shown Installation is without user input. EULA is accepted automatically.
-backup
Specifies whether the installer performs backup on previous installation.
0 – Previous installation is not backed up.
1 – Previous installation is backed up.
-auto
Automatically selects the default answers and values to all the questions asked.
Notice this option will NOT accept automatically the EULA and GCPP. That can only be done by providing a config.xml fileSpecifies if the installation is automatic with default settings and forces the-quietargument.This flag automatically accepts both the End User License Agreement and the Chaos Global Consumer Privacy Policy. It is recommended to get acquainted with them first.
UI Text Box
colorlight-yellow
iconnote
If errors are encountered with quiet installation, -ignoreErrors specifies what further actions will be are taken.
The installer automatically generates an uninstaller shortcut in the installation directory and registers it in the system's uninstaller registry.
A configuration file is automatically created by the installer whenever it runs with gui=0 (console mode) and when it is not already started with one. The file is created in the directory of the installer.
Variables
The automatic creation excludes variables which should not be set by the configuration files.
Example Console Installation
following is the list of variables that can be used in the configuration file:
Variable Name
Description
Default Value
STDROOT
Specifies the standard root directory for Anima installation. [path]
C:\Program Files\Chaos\Anima
EULA_AGREED
Indicates if the End User License Agreement has been agreed to. [0/1]
0 (not accepted)
GCPP_AGREED
Indicates if the Global Consumer Privacy Policy has been agreed to. [0/1]
0 (not accepted)
INSTALL_TYPE
Defines the type of installation. [0/1]
- 0: Workstation
- 1: Render node
0 (Workstation)
INSTALL_MS_CPP
Indicates if the Microsoft C++ Redistributable should be installed. [0/1]
**NOTE:** Only recommended for use if automatic detection fails.
autodetect
INSTALL_MS_NET
Indicates if .NET features should be installed. [0/1]
autodetect
CREATE_DESKTOP_SHORTCUT
Controls if a desktop shortcut for Anima 6 should be created. [0/1]
1 (create)
LAUNCH_ANIMA
Controls if Anima 6 should be launched after installation. [0/1]
1 (launch)
PLUGIN_PPP_VVVV_INSTALL
Controls the installation of the plugin. [0/1]
- PPP: target plugin (CIM, 3DS, UNR, PIX)
- VVVV: version (2020, 2021, 2022, 2023, etc.)
autodetect
PLUGIN_PPP_VVVV_PATH
Path of the target program of the plugin. [path]
autodetect
Plugin Variables
The following is a list of all possible variable names for plugins in the current version of Anima (the "X" at the end should be changed to "INSTALL" or "PATH"):
Autodesk 3ds Max:
  • PLUGIN_3DS_2026_X
  • PLUGIN_3DS_2025_X
  • PLUGIN_3DS_2024_X
  • PLUGIN_3DS_2023_X
Cinema 4D:
  • PLUGIN_CIN_2025_X
  • PLUGIN_CIN_2024_X
  • PLUGIN_CIN_2023_X
  • PLUGIN_CIN_R26_X
Unreal Engine:
  • PLUGIN_UNR_5.5_X
  • PLUGIN_UNR_5.4_X
  • PLUGIN_UNR_5.3_X
  • PLUGIN_UNR_4.27_X
Pixotope:
  • PLUGIN_PIX_P23.1_X
  • PLUGIN_PIX_P23.4_X
Console Installation Examples
  • Simple example of an automatic installation without GUI and
  • interactive EULA acceptance:
Code Block
.\anima_installer_6._1_0_baa9803d70.0.exe -gui=0 -auto
  • Silent install example command that:
    • runs without GUI
    • selects the options provided thorugh a config XML file placed in the same folder as the installer
    • outputs a detailed log of the whole install process in the user temp folder (i.e. "C:\Users\admin\AppData\Local\Temp\installer_debug_2025_05_19_10_32_08.log")
Code Block
-configFile="C:\xxx\xxx\...\config.xml" -debug=13
  • Example of a
  • config XML file that could be used in the silent install example command shown above, and will:
    • automatically accept EULA (EULA_AGREED) and GCPP (GCPP_AGREED)
    • install Anima in Workstation mode (INSTALL_TYPE) on the specified path (STDROOT)
    • will not install any third-party libs (INSTALL_MS_CPP, INSTALL_MS_NET)
    • will not create a desktop shortcut (CREATE_DESKTOP_SHORTCUT)
    • will automatically install all plugins (autodetect which ones can be installed and in which path)
    • and will not launch Anima after the installation is finished (LAUNCH_ANIMA):
Code Block
<?xml version="1.0" encoding="UTF-8"?>
<DefValues>
    <Value Name="EULA_AGREED" DataType="value">1</Value>
    <Value Name="GCPP_AGREED" DataType="value">1</Value>
    <Value Name="STDROOT" DataType="value">C:\xxx\...\xxx</Value>
    <Value Name="INSTALL_TYPE" DataType="value">0</Value>
    <Value Name="INSTALL_MS_CPP" DataType="value">0</Value>
    <Value Name="INSTALL_MS_NET" DataType="value">0</Value>
    <Value Name="CREATE_DESKTOP_SHORTCUT" DataType="value">0</Value>
    <Value Name="LAUNCH_ANIMA" DataType="value">0</Value>
</DefValues>
  • Similar config XML example as before, but now installing the Render Node mode and specifying whether each plugin should be installed or not
    • install Anima in Render Node mode (INSTALL_TYPE) on the specified path (STDROOT)
    • Installs the plugin for 3dsMax 2023 in the specified path
    • Does not install any other plugins
Code Block
<DefValues>
    <Value Name="INSTALL_TYPE" DataType="value">0<>1</Value>
    <Value Name="PLUGIN_3DS_2023_INSTALL" DataType="value">1</Value>
    <Value Name="PLUGIN_3DS_2023_PATH" DataType="value">C:\xxx\...\3ds Max 2023</Value>
	<Value Name="PLUGIN_3DS_2024_INSTALL" DataType="value">0</Value>
    <Value Name="PLUGIN_3DS_2025_INSTALL" DataType="value">0</Value>
    <Value Name="PLUGIN_3DS_2026_INSTALL" DataType="value">0</Value>
    <Value Name="PLUGIN_CIN_R26_INSTALL" DataType="value">0</Value>
    <Value Name="PLUGIN_CIN_2023_INSTALL" DataType="value">0</Value>
    <Value Name="PLUGIN_CIN_2024_INSTALL" DataType="value">0</Value>
    <Value Name="PLUGIN_CIN_2025_INSTALL" DataType="value">0</Value>
    <Value Name="PLUGIN_UNR_4.27_INSTALL" DataType="value">0</Value>
    <Value Name="PLUGIN_UNR_5.3_INSTALL" DataType="value">0</Value>
    <Value Name="PLUGIN_UNR_5.4_INSTALL" DataType="value">0</Value>
    <Value Name="PLUGIN_UNR_5.5_INSTALL" DataType="value">0</Value>
    <Value Name="PLUGIN_PIX_P23.1_INSTALL" DataType="value">0</Value>
    <Value Name="PLUGIN_PIX_P23.4_INSTALL" DataType="value">0</Value>
</DefValues>
Variables
Variable Name
Description
Default Value
STDROOT
EULA_AGREED
0 (not accepted)
GCPP_AGREED
0 (not accepted)
INSTALL_TYPE
- 0: Workstation
- 1: Render node
0 (Workstation)
INSTALL_MS_CPP
autodetect
INSTALL_MS_NET
autodetect
1 (create)
LAUNCH_ANIMA
1 (launch)
autodetect
autodetect
List of Plugin Variables
Autodesk 3ds Max:
  • PLUGIN_3DS_2026_X
  • PLUGIN_3DS_2025_X
  • PLUGIN_3DS_2024_X
  • PLUGIN_3DS_2023_X
Cinema 4D:
  • PLUGIN_CIN_2025_X
  • PLUGIN_CIN_2024_X
  • PLUGIN_CIN_2023_X
  • PLUGIN_CIN_R26_X
Unreal Engine:
  • PLUGIN_UNR_5.5_X
  • PLUGIN_UNR_5.4_X
  • PLUGIN_UNR_5.3_X
  • PLUGIN_UNR_4.27_X
Pixotope:
