width40%
To delete individual actors, select anActorand press theDeletekey.
width5%
width55%
Before after
Panel
Image Added
Panel
Image Added
Image_comparison_slider
LabelBeforeBefore
InitVisibleRatio0.25
LabelAfterAfter
AttachmentImageAfter
width40%
To delete all actors, select the animaProject001 object, which is the root Anima node for all the actors and scenes, and then press the Delete key.
width5%
width55%
