This page provides information about the Variation tab in Chaos Envision.
width60%
Chaos Envision lets you create and manage as many variations of your current project as you need. You can use these variations to explore design options or even animate between them.
There are two types of variations that you can create:
Fancy Bullets
typecircle
  • Scene – Refers to the objects in your scene. Across these variations, you can change the position, scale, rotation, or visibility of selected objects.
  • Environment – Refers to the environment lighting of the scene. Across these variations, you can modify all environment lighting parameters found in the Environment tab, and achieve different lighting scenarios.
In the Variations tab, you can create scene variations.
Within the Envision timeline, the scene variations have their own track, allowing you to creatively combine and transition between them.
Selecting a variation from the variations list updates the viewport immediately in real time. Alternatively, you can switch between variations from the current view quick settings
width5%
width35%
Manage Variations
width60%
The currently applied variation is highlighted in blue and indicated with a check mark () in the variations list. You can search, create and delete variations as described in the table below.
Search for a specific variation using the Search field. It filters the variations list and shows only those variations that contain the entry from the search field. Click thebutton on the right to clear the search.
Create a new variation.
Delete the selected variation.
UI Text Box
colorlight-cyan
iconinfo
typeinfo
A yellow frame around the viewport and a yellow highlight of the variation name appear every time a change is made to the current variation to prevent you from modifying it inadvertently.
UI Text Box
colorlight-cyan
iconinfo
When variations are used in the Animation Timeline, a transition indicator () appears next to them in the Variation list if the playhead is over a transition element in the Variations track.
width5%
width35%
Actions with Variations
width60%
A context menu is available when you right-click on a variation, allowing you to perform some additional actions with variations.
Duplicate – Duplicates the selected variation. Shortcut: Ctrl+D
Delete – Deletes the selected variation.
Rename – Renames the selected variation.
Copy – Copies the selected variation.
Paste all changes – Pastes all changes from one variation to another.
Paste transforms – Pastes all transformation changes from one variation to another.
Paste materials – Pastes all materials from one variation to another.
Paste lights – Pastes all lights from one variation to another.
width5%
width35%
See Also:
Thumbnailspagesettings
ThumbnailOverlayRectangleColour0,0,0
ThumbnailOverlayRectangleOpacity0.5
ThumbnailBGImageHeight100px
ThumbnailOverlayOpacity0
ThumbnailSubTextSize13px
ThumbnailTextColourWhite
ThumbnailTitleTextSize22px
ThumbnailOverlayRectangleHeight80%
ThumbnailOverlayRectangleBottomPadding10px
Responsivegridmacro
VAlignmentstart
Columns2repeat(2, 1fr)
Columns3width1000px
Columns1repeat(3, 1fr)
Columns1width1540px
Columnsrepeat(4, 1fr)
Columns2width1290px
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
classdashboard
Textboxcard
PageToIncludeMenus
CardPageLinkEnvironment (Variations) Tab
Environment Variations
Textboxcard
PageToIncludeMenus
CardPageLinkAnimation Tab
Variations in Animation
Textboxcard
PageToIncludeMenus
CardPageLinkEnvironment Tab
Environment Setup
Textboxcard
CardPageLinkCurrent View Quick Settings
Textboxcard
CardPageLinkFull Screen Viewport
