If you have a Named license, follow these steps. The steps are the same for connecting to an online floating license pool.
Fancy Bullets
type
circle
During the default installation, the license application is installed locally on your machine. For more information on the specifics of the installation, go to the Installationpage.
Once you start a render with V-Ray, you are prompted to verify your license by signing in.
width
5%
width
50%
Image Added
width
45%
Alternatively,
Open Maya and go
to
to V-Ray menu > Licensing > Chaos Account.
Select Sign in from this dialog and enter your Chaos account credentials on the Chaos accounts Sign in webpage.
width
5%
width
50%
width
45%
If you don't sign in first, and attempt to render with V-Ray, you are prompted to verify your license by signing in.
