Chaos offers a free trial of Corona for 3ds Max before purchasing. The trial period has no restrictions within the software such as watermarks. This means that what you see in the trial is exactly what you will get if you have a paid subscription.
The Corona Free Trial activation consists of the following steps:
  • Go to the trial page and start your free trial
  • Complete the checkout processRegister a new account or sign into an existing one at www.chaos.com.
  • Download Corona.
  • Install Corona.
  • Start Activate your trial .license
The steps below guide you as a first-timer on how to activate the trial license.
Steps
The steps for activating the trial vary depending on the Corona version you are using:
auitabs
UI Text Box
typetip
Click any image to view it in higher resolution.
directionhorizontal
Tabs Page
titleCorona 12, Update 2 and later
UI Steps
sizesmall
UI Step
width60%
Visit the Free Trial Page
Go to the Corona Trial Page and click Start your trial under the product you would like to try. You can choose whether your license is Named or Floating, whether you want the Solo or Collection product bundle, and if you would like the subscription to be monthly or annual. To learn more, see: Chaos Suite offerings.
Create an Account
Register an account in order to use and activate the trial, or use an existing Chaos account. For new users, please use this link to register an account: https://accounts.chaos.com/register
Once registered, you will receive an email from Chaos to confirm your account. If you do not receive the email, please check your spam folder in case it has been filtered there. If you still cannot find the email from Chaos, please contact the Chaos support team for further assistance using this link: Contact Support
width5%
width35%
Image Removed
Image Added
Download Trial Product
UI Step
Go to the Chaos download page to download the latest release. This can be found here: https://my.chaos.com/download/build?product=Corona
Install Trial Product
Run the installer and complete the installation process as explained on the Installation Process page.
UI Step
UI Step
100%Go to the addresshttp://localhost:30304/ and:
  • If you see a green dot next to Online licensing and a Corona icon listed under your products - you are good to go!
  • If you see a Sign in button - click on it and proceed with the sign in process.
width
60%
UI Step
Complete the Checkout Process
Enter your email address and billing details, and complete the checkout process.
Activate License
Open up 3ds Max and set the renderer to Corona. You are presented with a pop-up window.
Click Get a free trial and follow the prompts.
ui-red
ui-
width60%
text-box
colorlight-
cyan
icon
no-icon
Note: If you cannot see the Get a free trial button in the pop-up window, close the window and try again by setting Corona as your active renderer or starting a render.
width5%
width35%
Image Removed
UI Step
Sign into your account to activate the trial
info
Billing starts automatically after the free trial. Cancel before it ends to avoid getting billed
width60%
width5%
width35%
Image Removed
Image Added
UI Step
width60%
Complete the short survey to continue and finalize the activation process.
width5%
width35%
Image Removed
UI Step Section
width60%
Back in 3ds Max, the Chaos licensing pop-up window should disappear.
width5%
width35%
UI Step Section
width60%
Chaos Corona for 3ds Max is now active on your system. You can confirm this from the Render Setup > System > About Chaos Corona/Licensing rollout.
A successful activation switches the "Activate license" button to the "Online help" button.
Alternatively, you can also check the status of your license in the Chaos License Server
width5%
width35%
Image Removed
Activate your Chaos Account (non-registered users)
UI Text Box
colorlight-cyan
iconinfo
If you already have a Chaos account, you can skip this step.
After completing the checkout process, you will receive an account setup email from Chaos. Use the link in the email to set a password and activate your account.
Image Removed
In the Render Setup window, go to System > About Corona and click Activate license...
UI Step
Download and Install Corona
width30%
1. Click the Download button to be redirected to the Active Products page in my.chaos.com.
Image Added
width5%
width30%
2. Here, again, click the Download button next to the newly acquired Corona subscription.
Image Added
Tabs Page
titleCorona 12, Update 1 and previous
Image Removed
Go to the Chaos download page to download the latest release. This can be found here: https://www.chaos.com/corona/download
UI Steps
sizesmall
UI Step
width60%
Create an Account
width5%
width35%
UI Step
UI Step
UI Step
width60%
Activate License
Open up 3ds Max. Go to Render Setup > Renderer and set Corona as your active renderer.
width5%
width35%
UI Step
width60%
width5%
Image Removed
width
35%
UI Step
width60%
You are presented with a pop-up window with various options. Click Activate Trial and follow the prompts.
width5%
width35%
Image Removed
UI Step Section
width60%
Sign into your account to activate the trial.
width5%
width35%
Image Removed
30%
3. On the Download page, choose the 3ds Max version you are using and click Download for Windows. When the download is complete, run the installer and follow the on-screen instructions to complete the installation.
Image Added
UI Text Box
colorlight-cyan
iconinfo
To learn more about the installer and its options, see Installation Process.
UI Step
Image Removed
Go to the address http://localhost:30304/ and:
If you see aSign in button - click on it and proceed with the sign in process. That's all!
  • Back in 3ds Max, you may notice that the activation window is still open. Click Retry to close this.
    width60%
    width5%
    width35%
    UI Step
    Activate License
    When you open up 3ds Max and set the renderer to Corona, a pop-up window appears. Click Sign in. Once you are signed in, the trial license is activated, and the pop-up window in 3ds Max disappears.
    UI Step
    width60%
    width5%
    width35%
    Image Removed
    Image Added
    UI Step
    width60%
    by going to
    . If your license is active, you will see the Online Help button instead of the Activate license... button.
    rollout.
    A successful activation switches the Activate license button to the Online help button.
    width5%
    Image Removed
    width35%
    Image Added
    Cancelling the Subscription
    If you wish to cancel the subscription, you can do so from the Active Products page of the my.chaos website. The Cancel subscription link is located next to the Auto renewal status.
    Click on the link, fill out the questionnaire, and you will cancel the subscription.
    Image Added
