Go to the Corona Trial Pageand click Start your trial under the product you would like to try. You can choose whether your license is Named or Floating, whether you want the Solo or Collection product bundle, and if you would like the subscription to be monthly or annual. To learn more, see: Chaos Suite offerings.
width
5%
width
35%
UI Step
width
60%
Complete the Checkout Process
Enter your email address and billing details, and complete the checkout process.
UI Text Box
color
light-cyan
icon
info
Billing starts automatically after the free trial. Cancel before it ends to avoid getting billed.
width
5%
width
35%
UI Step
Activate your Chaos Account (non-registered users)
UI Text Box
color
light-cyan
icon
info
If you already have a Chaos account, you can skip this step.
After completing the checkout process, you will receive an account setup email from Chaos. Use the link in the email to set a password and activate your account.
UI Step
Download and Install Corona
width
30%
1. Click the Download button to be redirected to the Active Products page in my.chaos.com.
width
5%
width
30%
2. Here, again, click the Download button next to the newly acquired Corona subscription.
width
5%
width
30%
3. On the Download page, choose the 3ds Max version you are using and click Download for Windows. When the download is complete, run the installer and follow the on-screen instructions to complete the installation.
When you open up 3ds Max and set the renderer to Corona, a pop-up window appears. Click Sign in. Once you are signed in, the you can use Corona with your trial licenseis activated, and the pop-up window in 3ds Max disappears.
width
5%
width
35%
UI Step
width
60%
You can now use Chaos Corona for 3ds Max is now active on your system. You can confirm this from the Render Setup > System > About Chaos Corona/Licensing rollout.
A successful activation switches the Activate license button to the Online help button.
Alternatively, you can also check the status of your license in theChaos License Server.
