width50%
If you are updating your licensing system from the previous setup to the new online system, no changes are required on the workstation or application side of your software. The online system replaces the existing dongle functionality without any additional steps needed on your part. There is no need to use the Change License Settings application to reconfigure your setup. If you have purchased online licenses, these can be activated for online usage in the new system right away.
UI Text Box
typenote
The username and password credentials in the Manually Change your license IP tool window are not the same as your online credentials used to log into your account at my.chaos.com and activate the License Server.
width5%
width45%
