width55%
The Fog rollout provides controls for simulating participating media like fog, atmospheric dust and so on. The rollout is located under the Environment tab in the right-hand side panel.
width5%
width40%
Align
aligncenter
Before after
afterLabelFog_Enabled
beforeLabelFog_Disabled
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Image_comparison_slider
AddButtonsfalse
LabelBeforeNo Fog
LabelAfterWith Fog
AttachmentImageAfter
width65%
Enable fog – Enables aerial perspective fog to be applied in the scene. See the Overview section above.
Fog visibility range – Specifies the distance in km at which the fog has absorbed 90% of the light coming from objects behind it. Lower values make the fog appear denser, while larger values reduce the effect. See the Fog Visibility Range example below.
Fog height – Specifies the height of the fog layer in meters. See the Fog Height example below.
Fog start distance – Specifies the distance from the camera at which the fog starts. See the Fog Start Distance example below.
Fog max opacity – Specifies the maximum opacity of the fog. A value of 1 means the fog is completely opaque, while 0 means the fog is invisible. See the Fog Max Opacity example below.
Fog color – Specifies the color of the fog layer. See the Fog Color example below.
width5%
width30%
