You can see the effect of 0% Transmission in the following screenshots with 25% and 75% outlines applied.
Before after | ||||||||||
Align | ||||||||||
Image_comparison_slider | | |||||||||
width | 50% | |||||||||
AttachmentImageBefore | rs_win9_4-0.png | |||||||||
AttachmentImageAfter | rs_win10_4-0.png | height | 50%
Bump Maps
Section | ||||||||||||||||||||||||||||||||
Light View Temperature Gauge
This gauge will only be viewable in the Enscape window, and is not included in rendered images.
Before after | ||||||||||||
| 5%
| column
| width
| 50% | ||||||||
Column | ||||||||||||
You can also combine Light View mode with Outlines. In the example, the outlines are set to different % values.
Before after | |||||||||||||||||||||||||||||
Sketch Mode
