This example shows the difference between Random distribution and UV map modes.
width | 25% |
Column | |||||||||||||||||||
Before after | ||||||||||
Anchor | ||||
Anchor | ||||
Section | ||||||
width | 25% |
Section | |||||||||||||||||||
The bounding box of the model is represented with a red box. The pivot of the model is represented with a blue sphere.
Sectionbefore-after | |||||||||||||||||||||||||||||
| width
| 25%
| column
When Edge trimming is off, the whole clumps are scattered causing some of the flowers (sub-object elements) to grow outside of the distribute-on object. Each model is scattered as expected (its pivot is placed within the boundaries of the distribute-on object), however the sub-mesh elements (individual flowers) are growing outside of the boundaries, because they are a part of the model.
The Local and World Slope Limitations determine the up-vector. The Local option uses the normals of the Distribute-on target object; the World option uses the Z-axis of the scene. In this example, the Slope Limitation Angle [°] is set to 0.0-45.0.
Column | |
width | 25%
Altitude Limitation
