width50%
The Reflection Filter Render Channel stores reflection information calculated from the materials' reflection values in the scene. Surfaces with no reflection values set in their material(s) contain no information in the render pass and, therefore, render black.
While the Raw Reflection Render Channel gives the full reflection of objects reflecting in the scene, the Reflection Filter shows how much of that reflection should come through in the composite. In other words, the filter defines the strength of the reflection, while the raw image defines what is being reflected in the image. When these two channels are multiplied, the true level of reflection is given and produces the Reflection Render Channel. Using these component parts of the reflection, you can fine-tune the reflection in your final composite.
The Reflection Filter channel is a sub-component in the main Beauty Pass.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Advanced > V-Ray Reflection Filter
width5%
width45%
Image_comparison_slider
LabelBeforebeauty render
width80%
LabelAfterreflection filter
height80%
Image Added
Properties
width50%
Enable Deep OutputSpecifies whether to include this render channel in deep images.
Color Mapping –
width5%
width45%
Image RemovedImage Added
Common Uses
The Reflection Filter Render Element is useful for changing the appearance of Reflective elements after rending, in a compositing or image editing software. In the example, the contrast of the Reflection Filter is increased, which makes reflective objects even more reflective.  The  The Raw Reflection render channel is used to colorize the reflections - the floor has a cool tint applied, and the ceiling - has a warm tint.
columnwidth
Sectionbefore-after
dark
true
20%
Panelcolumn
borderStylewidthnone60%
Image Added
20%
Panel
borderStylenone
Image Added
width80%
LabelAfterenhanced reflections
height80%
width
