width50%60%
The Raw Coat Filter Render Channel is similar to the Coat Filter Render Channel, except it is not affected by Fresnel falloff. The result is a solid mask showing the areas of reflection calculated from the V-Ray Mtl Coat Layer.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Raw > V-Ray Raw Coat Filter
width5%
80%
width45%35%
Image Added
Image_comparison_slider
LabelBeforebeauty render
width80%
LabelAfterraw coat filter
height
Properties
width50%
Enable Deep Output Specifies whether to include this render channel in deep images.
Color Mapping
Denoise – Enables the render channel's denoising, provided the Denoiser is enabled.
width5%
width45%
