This page provides information about the Raw Coat Filter Render Channel in V-Ray for Blender.
The Raw Coat Filter Render Channel is similar to the Coat Filter Render Channel, except it is not affected by Fresnel falloff. The result is a solid mask showing the areas of reflection calculated from the V-Ray Mtl Coat Layer.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Raw > V-Ray Raw Coat Filter
Properties
Enable Deep Output  Specifies whether to include this render channel in deep images.
Color Mapping
Denoise – Enables the render channel's denoising, provided the Denoiser is enabled.
