The Material ID Render Channel isolates objects with specific materials by Material ID for compositing purposes. This render channel provides a mask for individual objects and materials that is easy to select in compositing software.
This render channel either shows each material (by Material ID) as a solid unshaded color or stores the Material IDs as integer values within the EXR format or VRay Image Format file.
The Color (with Anti-Aliasing) method supports antialiasing at the edges of objects where they meet other objects or the background. The Integer (no Anti-Aliasing) method, which assigns a Material ID to each pixel in the render channel, does not support antialiasing as each pixel can have only a single Material ID assigned to it.
More than one Material ID render channel can be used if desired, for example, if you wish to have both solid-shaded color and integer-based render channels for maximum flexibility during compositing.
UI Path:||V-Ray Node Editor|| >World>Render Channels>Matte>V-Ray Material ID
width
5%
width
45%
Image_comparison_slider
LabelBefore
beauty render
width
80%
LabelAfter
material id channel
AttachmentImageBefore
AttachmentImageAfter
height
80%
Image Added
Properties
width
50%
Channel Name– Customizable name for the render channel.
Enable Deep Output–Specifies whether to include this render channel in deep images.
Color Mapping–
Consider For Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Filtering – – Applies an image filter to this channel.
Vfb Color Corrections– Applies the post-render color adjustments made from the VFB.
