width50%60%
The Multi Matte ID Render Channel provides a mask for individual objects and/or materials based on the Multi Matte IDs.
The Multi Matte ID Render Channel contains no shading information at all; it only contains blocks of color that correspond to each Multi Matte ID. It uses the Multi Matte ID option available in the materials' properties.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Matte > V-Ray Multi Matte ID
width5%
80%
width45%35%
Image Added
Image_comparison_slider
LabelBeforebeauty render
width80%
LabelAftermulti matte ID
height
Properties
width50%
Enable Deep Output – Includes this render element in deep images.
width5%
width45%
