width50%
 The Lighting Render Element stores direct lighting information from lights in the scene and materials as lit by the lighting. This render element can be used to brighten, lessen, or tint the direct lighting in a composite.
The VRayLighting render element is the same as VRayRawLighting multiplied by VrayDiffuseFilter. VRayLighting is provided as a convenience to the compositor.
This render element can be used to enhance the direct lighting in a scene after it is already rendered. See the example.
UI Path: ||V-Ray|| > Render Elements > Lighting
How to add a render element to a scene
Multiexcerpt include
MultiExcerptNameAddBackground
PageWithExcerptAtmospheric Effects RE
width5%
width45%
Image_comparison_slider
LabelBeforebeauty render
LabelAfterlighting channel
Image Added
Properties
width62%
Enable Deep OutputSpecifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in the Color Mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post-render color adjustments made from the VFB.
width5%
width33%
In this example, the direct lighting in the scene is tinted and reduced to create a more warm feeling. This is done by adjusting the Multiplier VFB property of the Lighting render element.
aligncenter
LabelBefore
before-after
width
Panel
60%
borderStyle
LabelAfter
none
after
Image Added
height
Panel
borderStylenone
Image Added
60%
UI Expand
titleClick here for the composition setup...
