Progress Bar Container
step2
Progress Bar - Hyperlink Step
titleStep 1: Install V-Ray
url Installation
titleStep 2: Activate V-Ray
urlChaos License Quick Start Guide
titleStep 3: Load V-Ray in Revit
urlLoading V-Ray
Activate the License
The Chaos License Server is the bridge between the Chaos Product and the Chaos Account associated with a given license. You cannot use any Chaos product without a license.
You connect to the License Server by installing the license application locally on your machine or connecting to a machine in your local network that has a shared Premium license set up.
If you are hosting a Premium Chaos License Server for multiple machines, please see the License Server Deployment.
Please follow the instructions for your subscription plan:
Steps
UI Steps
UI Step
width45%
Start Revit.
Press the Enable V-Ray button.
UI Expand
titleEngage V-Ray Automatically...
If you prefer your V-Ray license to be engaged automatically every time when Revit is loaded, use the Obtain License on start-up option.
Image Added
width5%
width50%
Image Added
UI Step
width45%
The first time you use V-Ray, a prompt to log in with your Chaos account may appear.
width5%
width50%
Image Added
UI Step
width45%
Alternatively,
If you have a Chaos Solo license plan or are connected to a Cloud-Based Floating License, follow these steps.
Fancy Bullets
typecircle
During the basic installation setup, the license application is installed locally on your machine. For more information on the specifics of the installation, go to the Installation page.
  • Open Revit and go to V-Ray Ribbon >
Online Help >
  •  Chaos Account.
  • Select Sign in from this dialog
and enter your Chaos account credentials on the Chaos accounts Sign in webpage
width5%
width50%
Image Modified
20%
UI Step
width45%
If you attempt to use V-Ray without signing in first, you are prompted to verify your license by signing in
Fancy Bullets
typecircle
  • Enter your Chaos credentials.
UI Text Box
typetip
You can use your Chaos account credentials.
Your existing Enscape, V-Ray, Corona, Anima or Veras logins are all Chaos accounts and work for all our products.
UI Text Box
typeinfo
If you have never had a Chaos account, you can create one at this step.
width
5%
width
35%
Image Removed
50%
Image Added
Chaos Single Sign-On Page
UI Step
width45%
The Premium License can be shared between multiple users and devices, or it can be used locally - similar to the Solo License. If you only plan to use the license on your machine, see the Solo License section.
When doing a shared setup for a Premium license, the license holder needs to install the license locally on at least one machine in the network. Installing the license happens automatically when you perform a default Chaos product installation. If you only need to install the License Server application separately, see the Installation page. This machine can use the license, but it also serves as a connection point for others to connect to the license. If you are the license holder, i.e., the administrator, see the License Server Deployment page.
Here is how to connect to an already set-up Premium shared license:
Fancy Bullets
typecircle
  • The administrator needs to give you their machine's IP address. This serves as your connection point to the Chaos License.
  • When installing your Chaos product, at the Licensing step, select Remote. In the Primary License Server field, type the server IP address that your license administrator gave you. At the end, add the :30304 port.
  • Continue to finish the installation. You are connected to the active licenses after that.
width5%
width50%
Image Removed
Example screenshot
Borrow Licenses for Offline Use
You can close the login page after seeing the confirmation for a successful login.
You can now start using your Chaos product.
width5%
width50%
Image Added
Sign in confirmation
UI Text Box
colorlight-yellow
iconnote
You can use the license server that installs automatically with the product to check the availability of your licenses. See how here.
Floating Licenses
Floating Licensescan be sharedbetween multiple users and can be used completely online or within a local network, depending on the setup.
To use an online floating pool, your Administrator needs to add you to their Organization. This sends an automatic email confirmation, which also contains a link you can use to create an account, if you don't have one yet.
After that, you can follow the same activation steps as above to connect to the online floating pool.
  1. Proceed with a default installation.
  2. Sign in with your Chaos Account when prompted.
If you are an Administrator in an Organization, see the Cloud-Based Floating Licensing page for a guide on how to share licenses through the my.chaos portal.
UI Text Box
colorlight-cyan
iconinfo
If your organization prefers to centrally manage licenses, enable anonymous device-based access, or deploy licenses within an offline or secure network environment, refer to the License Server Deployment
page.
Troubleshooting
If you are experiencing any difficulty installing or running the Chaos License Server, please refer to the Troubleshooting page for possible solutions.
Panel
borderColorred
borderStylesolid
Visit the License Server section of the documentation for further details on the Chaos License Server, such as how to check your license expiration and status, how to access various settings, and more advanced options.
Next Step
If you are using V-Ray version 7.0 or earlier, the activation of your license is part of the installation process. At the end of the installation you are prompted to sign in with your Chaos account in the web browser.
step2
url Installation
