Progress Bar Container
step2
Progress Bar - Hyperlink Step
titleStep 1: Install V-Ray
url Installation
titleStep 2: Activate V-Ray
urlChaos License Quick Start Guide
titleStep 3: Load V-Ray in Maya
urlV-Ray Configuration
Steps
Steps
UI Steps
UI Step
width45%
Start Maya.
Open the Plugin Manager from the Windows > Settings/Preferences > Plug-in Manager menu. Load the vrayformaya.mll plugin.
width5%
width50%
Image Added
UI Step
If you have a Named license, follow these steps. The steps are the same for connecting to an online floating license pool.
width45%
The first time you use V-Ray, a prompt to log in with your Chaos account may appear.
width5%
width50%
Image Modified
UI Step
width45%
Alternatively,
Fancy Bullets
typecircle
  • Open Maya and go to V-Ray menu > Licensing > Chaos Account.
  • Select Sign in from this dialog.
width5%
width50%
Image Modified
UI Step
width45%
Fancy Bullets
typecircle
  • Enter your Chaos credentials.
UI Text Box
typetip
You can use your Chaos account credentials.
Your existing Enscape, V-Ray, Corona, Anima or Veras logins are all Chaos accounts and work for all our products.
UI Text Box
typeinfo
If you have never had a Chaos account, you can create one at this step.
width5%
width50%
Image Modified
Chaos Single Sign-On Page
UI Step
width45%
You can close the login page after seeing the confirmation for a successful login.
You can now start using your Chaos product.
width5%
width50%
Image Modified
Sign in confirmation
UI Text Box
colorlight-yellow
iconnote
You can use the license server that installs automatically with the product to check the availability of your licenses. See how here.
If you are experiencing any difficulty installing or running the Chaos License Server, please refer to the Troubleshooting page for possible solutions.
  • If you are using V-Ray version 7.0 or earlier, the activation of your license is part of the installation process. At the end of the installation you are prompted to sign in with your Chaos account in the web browser.
Next Step
  • For more information on the vrayformaya.mll plugin, see the V-Ray
step2
url Installation
