The Light Select Render Element stores direct lighting information from user-selected lights in the scene.
Page Contents
Table of Contents | ||||
Section | |||||||||||||||
UI Path: ||Toolbar|| > V-Ray Menu icon > Render > VRayRenderElement > Type: Light Select
Inputs
The Light Select Render Element node allows one or more lights to be connected as inputs.
Properties
Apply Color Mapping – When enabled, color mapping will be applied to the Render Element.
Consider for Anti-Aliasing – When enabled, anti-aliasing will be used where possible.
Anchor | ||||
Normal – Lighting within the Light Select element behaves as normal and contains diffuse and specular information.
Raw – Lighting within the Light Select element behaves as a raw render element.
Diffuse – Lights within the Light Select element output only their diffuse contribution and contain no specular information.
Specular – Lights within the Light Select element output only their specular contribution and contain no diffuse information.
Fancy Bullets | ||
