Single executable that runs without Administrative privileges and without Internet connection
Free software - V-Ray license is not required
High DPI support
Known Issues
Fancy Bullets
type
circle
OS UI may be sluggish during GPU benchmark
GPU CUDA devices could be enabled/disabled from nVidia Control Panel only
If there is a proxy present, you should: 1. LAN Settings > Bypass proxy server for local addresses - should be turned on 2. Set environment variables HTTPS_PROXY and HTTP_PROXY before benchmarking
