Date – Apr. 4, 2017
Download Build – 1.0.1
Key Features
Fancy Bullets
typecircle
  • Measurement of CPU and CUDA GPU V-Ray rendering performance
  • Benchmark.chaosgroup.com site section for comparing benchmark results against other hardware
  • Single executable that runs without Administrative privileges and without Internet connection*
  • Free software - V-Ray license is not required
  • High DPI support
Fancy Bullets
typecircle
  • OS UI may be sluggish during GPU benchmark
  • GPU CUDA devices could be enabled/disabled from nVidia NVIDIA Control Panel only
  • Display of buckets in CPU rendering could be slower than the actual rendering on many-core machines. Even if it is - timing will be correct and will finish before drawing.
  • If there is a proxy present, you should set:
    1. LAN Settings >  > Bypass proxy server for local addresses - should be turned on
    2. Set environment variables HTTPS_PROXY and HTTP_PROXY before benchmarking
  • ON
* - Internet connection needed for accessing benchmark.chaosgroup.com to submit and/or compare results, but not to run benchmark tests.
