The Light Select Render Element stores direct lighting information from user-selected lights in the scene.
Page Contents
Table of Contents | ||||
Section | |||||||||||||||
Apply Color Mapping – When enabled, color mapping Color Mapping will be applied to the Render Element.
Anchor | ||||
Normal Direct illumination – Lighting within the Light Select element behaves as normal and contains diffuse and specular information.
Raw Direct raw – Lighting within the Light Select element behaves as a raw render element.
Diffuse Direct diffuse – Lights within the Light Select element output only their diffuse contribution and contain no specular information.
Specular Direct specular – Lights within the Light Select element output only their specular contribution and contain no diffuse information.
Full – Lights within the Light Select element provide full output for all information available in the scene such as GI, SSS, reflection, refraction, etc.
Common Use: Changing Lighting in Composite
Below is an example of how to use the Light Select Render Element in a composite.
The both Both of the element's mode's Types have been set to set to set to Normal Direct illumination.
The scene used for the images below uses only two lights, a VRaySunSky and a VRayLightMesh. Each have and each has their own Light Select render element assigned with the element's mode's have been set to set to Normal. The examples Render Element. The renders below show how the two Light Select render elements Render Elements can be combined to give the same result as the Lighting render elementRender Element, and combined with the Global Illumination render elementRender Element to give the equivalent of the Total Lighting render elementRender Element. This gives a fine finer level of control in the composite to change things such as the intensity, or color tinting of only some lights at a timefor individual lights within separate passes.
vrayRE_Light_Select Render Examples
Section | |||||||||||||||||||||||||
Note |
As the second light (the VRayLightMesh) contains no specular contribution at all, it is not rendered out for Light Select 2. |
Note | |||||||||||||||||||||||||||
Light Select Direct Diffuse, Direct Raw, and Direct Specular Types are combined by all Diffuse being merged together with a plus operation in the composite. The same is done to the Direct Raw and Direct Specular Types. The combined Direct Diffuse Light Select passes are then merged in composite with a Multiply operation with the Direct Raw Light Select passes. These are then merged with the Direct Specular Type Light Select passes, which then produces the same as the Lighting Render Element. If all these combined Light Select operations are then combined with the GI Render Element with a plus operation in composite the Light Total Render Element will be reproduced. As the Specular component is already present in the Light Select Render Elements, no Specular Render Element is needed to be present in the final composite. In the examples shown here, as the background is camera projected onto simple geometry and we do not need any extra lighting information added to it; A mask created from the inverted blue channel of a Multi Matte Render Element.
Fancy Bullets | ||
