stylecircle
Introduction
width50%
This tutorial covers the basic workflow of
importing a vrscene file and rendering from Unreal Engine with V-Ray for Unreal
. By the end of it, you will have a better understand of V-Ray for Unreal and how you can begin using it to render out your own scenes.
To follow this tutorial, you will need to have the V-Ray for Unreal plugin installed. This tutorial is a companion to go along with the QuickStart video posted on our YouTube channel and available here:
section
width30%5%
width40%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/0Se3D-PuBME" frameborder="0" gesture="media" allow="encrypted-media" allowfullscreen></iframe>
width30%
45%
 Image Added
Tutorial Assets
To download the files used in this tutorial, please click on the button below.
Note
You can right-click the download button and choose "Save Link As..." or "Save target as.." depending on your browser..  This will bring up a dialog to save the zip file without having to wait for the Preview mode to load.
Part I - Exporting the vrscene
Step 1.
Exporting vrscene from 3ds max
From  3ds max make sure you are looking through the camera you wish to render later in Unreal (1.1). Then you right click and select from the quad menu .vrscene exporter. A new window appears and where you select the export path and other various options. When finished click export (1.2). With this our vrscene is generated and we are ready to import it into Unreal engine.
width50%
Image Added
1.1
width50%
Image Added
1.2
Part II - Creating Unreal project and initial setup
Step 1.
Tutorial Steps
Launch Unreal Engine 4
Launch you version of Unreal from the Epic Games Launcher. (currently supported versions are 4.18.3 and 4.19). In (1.1). A window appears.  In the New Project Tab create a new project........
select the Blank template, Desktop/Console hardware, Maximum quality for the Editor and No Starter Content as initial setup. Choose the directory where you wish to create the project, name it and click the Create Project button (1.2).
width50%
Image Added
1.1
width50%
Image Added
1.2
Step 2. Enable The V-Ray Plugin
When you create a project you must first enable the V-Ray plugin. From "Edit/Plugins" enable the VRayForUnreal plugin. You will need to restart Unreal for this to take effect.(2.2)
width100%
Image Added
2.2
New level Creation
Test Lightbake
Render Image
Refine the Render inside the VFB
Save  the Render
