Multiexcerpt
MultiExcerptNameusbOnlineLicOverview
width50%
The licensing system allows you to use seats associated with your Chaos Group account easily from anywhere you can log into over the internet. If you also have a USB license dongle attached to your workstation/server, you can utilize those available licenses with the License Server.
Note that there might be some delays in detecting a dongle when it is plugged in. If however a dongle is not recognized at all by the system after plugging it in, try disabling and re-enabling the dongle subsystem.
width5%
width45%
If you need to upgrade your dongle please click the Upgrade and follow the instructions found on the Dongle Reprogramming page.
UI Text Box
typewarning
When using a dongle license connected to OLS the License Server you are only able to access the dongle licenses on the machine that the dongle is connected too.  You You are unable to access dongle licenses over the internet on another machine logged into OLSthe License Server.
