- On the same machine where the V-Ray license server is running, open the link link http://localhost:30304/getstatus.
- Next, you will need to look for your licenses. Please see the V-Ray Dongle Licensing page for more information on the type of licenses you need to look for.
- If you do not see your V-Ray licenses, this means that your dongle has to be reprogrammed as described in the Dongle Reprogramming page.
- If you don't see any free licenses, this means that all available licenses are in use and you can't have more concurrent users.
You might need to reconfigure the license settings on the machine where you want to use V-Ray. See the Changing your License Settings page for more information.
Note: If the V-Ray license server is running on the same machine as V-Ray, you can use localhost or 127.0.0.1 in the License server field.
