This page gives details on how to use a USB dongle in conjunction with the online licensing system.
Floatingpagetoc
MultiExcerptNameusbOnlineLicOverview
width50%
The licensing system allows you to use seats associated with your Chaos Group account easily from anywhere you can log into over the internet. If you also have a USB license dongle attached to your workstation/server, you can utilize those available licenses with the License Server.
Note that there might be some delays in detecting a dongle when it is plugged in. If however a dongle is not recognized at all by the system after plugging it in, try disabling and re-enabling the dongle subsystem.
width5%
width45%
Image Modified
   MultiexcerptMultiExcerptNameusbOnlineLicEnable
Enabling your Dongle Licenses
You can Enable your USB dongle by clicking on the Enable Dongle button.
Image Modified
Once your USB dongle is enabled you will be able to see your dongle information.
Image Modified
If you need to upgrade your dongle please click Upgrade and follow the instructions found on the Dongle Reprogramming page.
