Fractal Roughness – Controls the roughness of the fractal. A value of 0.0 is very rough and a value of 1.0 is very smooth, which negates the fractal. For more details, please see the Fractal Roughness examples below.
Color Tweaks
Mult – Specifies a strength multiplier for the texture color.
Invert – When enabled, inverts the resulting texture color.
Alpha Tweaks
Source – Specifies where the alpha channel is drawn from.
Tile V – Enables vertical tiling.
UV Noise
Image Modified
Enabled – Enables noise for the texture.
Anchor
exampleCellularSize
exampleCellularSize
Example: Size
width5%20%
columnwidthcolumn30%column
30%
width60%
Image slider
Panel
borderStylenone
Image Modified
Dots Size: 0.05
Panel
borderStyle
none
30%
Image Modified
 Dots Size: 0.1
Panel
borderStyle
width
none
Image Modified
Dots Size: 0.2
Panel
width5%
width30%
Image Removed
borderStyle
width5%
column30%column
none
Image Added
Chips Size: 0.2
Panel
borderStyle
width
none
Image Modified
Chips Size: 0.35
Panel
width5%
width
width30%
borderStyle
none
30%
Image Modified
 Chips Size: 0.5
Panel
width5%
columnwidthcolumnwidthcolumn
borderStylenone
Image Modified
Cells Size: 0.1
Panel
borderStyle
none
30%
Image Modified
Cells Size: 0.2
Panel
borderStyle
none
30%
Image Modified
Cells Size: 0.5
Panel
width5%
width30%
borderStyle
width5%
none
Image Modified
Chess Cells Size: 0.1
Panel
borderStyle
none
30%
Image Modified
Chess Cells Size: 0.2
Panel
borderStyle
width
none
Image Modified
Chess Cells Size: 0.5
Panel
width5%
width30%
Image Removed
borderStyle
width5%
none
Image Added
Plasma Size: 0.05
Panel
borderStyle
none
30%
Image Modified
Plasma Size: 0.07
Panel
borderStyle
none
30%
Image Modified
Plasma Size: 0.2
width20%5%
Anchor
exampleSpread
exampleSpread
Example: Spread
width5%20%
column30%columnwidthcolumn
30%
width60%
Image slider
Panel
borderStylenone
Image Modified
Dots Spread: 0.5
Panel
borderStyle
width
none
Image Modified
Dots Spread: 1.0
Panel
borderStyle
none
30%
Image Modified
 Dots Spread: 1.5
Panel
width5%
width30%
borderStyle
width5%
none
Image Modified
Chips Spread: 0.5
Panel
borderStyle
none
30%
Image Modified
Chips Spread: 1.0
Panel
borderStyle
width
none
Image Modified
 Chips Spread: 2.0
Panel
width5%
width30%
Image Removed
borderStyle
width5%
none
Image Added
Cells Spread: 0.1
Panel
borderStyle
width
none
Image Modified
 Cells Spread: 0.5
Panel
borderStyle
none
30%
Image Modified
 Cells Spread: 1.0
Panel
width5%
width30%
borderStyle
width5%
none
Image Modified
Chess Cells Spread: 0.1
Panel
borderStyle
none
30%
Image Modified
Chess Cells Spread: 0.5
Panel
borderStyle
width
none
Image Modified
 Chess Cells Spread: 0.9
Panel
width5%
width5%
width30%
borderStyle
none
Image Removed
Image Added
Plasma Spread: 1.0
Panel
borderStyle
none
30%
Image Modified
Plasma Spread: 3.0
Panel
borderStyle
none
30%
Image Modified
Plasma Spread: 5.0
width20%5%
Anchor
exampleDensity
exampleDensity
Example: Density
width5%20%
columnwidthcolumn
30%
width60%
Image slider
Panel
borderStylenone
Image Modified
Dots Density: 0.1
Panel
borderStyle
none
30%
Image Modified
 Dots Density: 0.25
Panel
width5%
30%
width30%
borderStyle
width
none
Image Modified
Dots Density: 1.0
Panel
width5%
columnwidthcolumn
borderStylenone
Image Modified
Chips Density: 0.25
Panel
borderStyle
none
30%
Image Modified
Chips Density: 0.7
Panel
width5%
30%
width30%
borderStyle
width
none
Image Modified
Chips Density: 1.5
Panel
width5%
borderStylenone
Image Modified
Cells Density: 0.15
Panel
borderStyle
width
none
Image Modified
Cells Density: 0.25
Panel
borderStyle
none
30%
Image Modified
 Cells Density: 0.5
Panel
width5%
borderStylenone
width5%
width
Image Modified
Chess Cells Density: 0.15
Panel
borderStyle
none
30%
Image Modified
 Chess Cells Density: 0.25
Panel
width5%
30%
width30%
borderStyle
width
none
Image Modified
Chess Cells Density: 0.5
Panel
width5%
borderStylenone
Image Modified
Plasma Density: 0.5
Panel
borderStyle
none
30%
Image Modified
 Plasma Density: 1.0
Panel
borderStyle
none
30%
Image Modified
Plasma Density: 2.0
width5%
20%
Anchor
exampleLow
exampleLow
Example: Low
width5%
width45%
The Dots examples below use Size: 0.25, Spread: 0.5, and Density: 1.5. The Edge Color is blue for visual clarity
section
Image slider
Panel
width5%
30%columnwidthcolumn30%
borderStylenone
width
Image Modified
Dots Low: 0.0
Panel
borderStyle
none
30%
Image Modified
Dots Low: 0.5
Panel
borderStyle
width
none
Image Modified
Dots Low: 1.0
width5%45%
The Chips examples below use Size: 1.0, Spread: 0.75, and Density: 3.0. The Edge Color is blue for visual clarity.
section
Image slider
columncolumn30%columnwidth
Panel
width30%
borderStyle
width5%
none
Image Modified
Chips Low: 0.0
Panel
borderStyle
width
none
Image Modified
Chips Low: 0.5
Panel
borderStyle
none
30%
Image Modified
Chips Low: 0.9
width5%
Anchor
exampleMiddle
exampleMiddle
Example: Middle
width5%
width45%
The Dots examples below use Size: 0.25, Spread: 0.5, and Density: 1.5. The Edge Color is blue for visual clarity.
section
Image slider
width30%
Panel
width5%
borderStylenone
Image Modified
Dots Middle: 0.0
Panel
borderStyle
none
30%
Image Modified
Dots Middle: 0.5
Panel
borderStyle
none
30%
Image Modified
Dots Middle: 1.0
width5%
45%
section
Image slider
columncolumnwidthcolumn30%
Panel
width30%
borderStyle
width5%
none
Image Modified
Chips Middle: 0.0
Panel
borderStyle
none
30%
Image Modified
Chips Middle: 0.5
Panel
borderStyle
width
none
Image Modified
Chips Middle: 1.0
width5%
Anchor
exampleHigh
exampleHigh
width5%
width30%
Fractal Roughness: 0.0
width30%
Fractal Roughness: 0.5
width30%
Fractal Roughness: 0.9
width5%
Color Tweaks
Image Removed
Offset – Color corrects the texture by adding the the RGB color values specified here to the RGB color values in the texture.
Alpha Tweaks
Image Removed
Source (question)
Mult – Specifies a multiplier for the texture alpha.
Offset – Specifies an additional offset for the texture alpha.
Invert – When enabled and Invert from Color Tweaks is also enabled, the resulting texture alpha will be inverted as well.
Placement
Image Removed
Placement Type – Specifies the way the valid portion of the texture is applied.
Full – Uses the full valid portion of the texture.
Crop – Allows the user to specify a section of the texture using the parameters below.
Place – Allows the user to specify a section of the texture and how to place it using the parameters below.
U – Specifies the U coordinate of the valid texture sector.
V – Sppecifies the V coordinate of the valid texture sector.
W – Specifies the width of the valid texture sector.
H – Specifies the height of the valid texture sector.
Tile U – Enables horizontal tiling.
UV Noise
Image Removed
Amount – Specifies the amount of noise to add to the texture.
Levels – Specifies the amount of noise iterations.
Size – Controls the scale of the noise.
Animated – Enables the noise to be animated.
