UI Paths
width5%
width45%33%
||shop Network|| > Material > V-Ray Material node > V-Ray > Material sub-menu
Image Added
width33%45%
 ||mat Network|| > V-Ray > Material sub-menu
width33%5%
Image Removed
V-Ray Material Builder Node
The V-Ray Material Builder (vrayMaterialBuilder) node is a container that allows you to create V-Ray materials, textures, and additional V-Ray nodes.
By default, it creates a V-Ray Material (BRDFVRayMtl) connected to a V-Ray Material Output node. For additional information, see the V-Ray Material Builder page.
List of V-Ray BRDF Materials
width5%
width30%
Blend
width30%
Bump Material | BRDFBump
width30%
Car Paint Material | BRDFCarPaint
width5%
width5%
width30%
Image Modified  Flakes Material  | BRDFFlakes
Hair
width30%
Image ModifiedHair Material | BRDFHair4
Light
width30%
Image Modified
Override
Light Material | BRDFLight
width5%
width5%
width30%
 Hair 3 Material | BRDFHair3
width30%
Scanned Material | BRDFScannedVRscans
width30%
Skin Material | BRDFSkinComplex
width5%
width5%
width30%
SSS 2 Complex Material | BRDFSSS2Complex
width30%
V-Ray alSurface Material | BRDFAlSurface
width30%
V-Ray Material | BRDFVRayMtl
width5%
List of Additional V-Ray Material Nodes
width5%
width30%
Two Sided Material | Mtl2Sided
width30%
VRmat Material | MtlVRmat
width30%
Wrapper Material | MtlWrapper
width5%
width5%
width30%45%
VRayToonMtl
V-Ray Toon Material
Image Removed
 Render Stats Material | MtlRenderStats
width30%45%
VRayMtlOSL
V-Ray OSL Material
Image Removed
Override | MtlOverride
width30%5%
Image Removed
Multi ID | MtlMulti
width5%
5%
Fancy Bullets
typecircle
width5%
width30%
Image Removed
 Material ID | MtlMaterialID
width30%
Image Removed
Round Edges | MtlRoundEdges
width30%
Image Removed
Single Material | MtlSingleBRDF
width
