UI Text Box
sizemedium
typetip
You can suppress showing of the dialogues offering presets using the inDontOfferPresets attribute of the Simulator.
Image Added
Image Removed
UI Text Box
sizemedium
typeinfo
Clicking the "..." button will open a menu with the following options:
Browse - Opens a dialog for choosing one of several cache file types. Phoenix FD can import the following cache files: Phoenix FD *.aur, Field3D *.f3d and OpenVDB *.vdb.  See How to import and render simulations from FumeFX, Houdini and Maya for more information.
Reset to Default - Resets the Preview and Render Path to the default value of $(same_as_output).
Help - Opens the Help page for the Input rollout of the Phoenix FD Simulator.
UI Text Box
sizemedium
typetip
Anchor
TimeBendControls
TimeBendControls
