This page contains information about the V-Ray Cellular Texture.
width50%
The V-Ray Cellular Texture map generates a procedural cellular noise pattern.
width5%
width45%
UI Paths
width33%
||mat Network|| > V-Ray> Texture > V-Ray Celluar
width33%
||shop Network|| > V-Ray Material > V-Ray> Texture > V-Ray Celluar
width33%
Node
The V-Ray TexCellular node provides inputs for controlling various texture properties. They correspond to parameters in the section below.
Type – Specifies which type to use for the Cellular texture. The choices are Dots, Chips, Cells, Chess Cells, or Plasma.
Size – Controls the size of the Cellular procedural texture. For more details, please see the Size examples below.
Spread – Controls the spread of the procedural Cellular texture. For more details, please see the Spread examples below.
Density – Controls the Density of the Cellular texture. For more details, please see the Density examples below.
Low – Controls the low threshold (background color). For more details, please see the Low examples below.
Middle – Controls the middle threshold (edge color). For more details, please see the Middle examples below.
High – Controls the high threshold (center color). For more details, please see the High examples below.
Fractal – Enables the addition of fractal generation. Only available with Dots and Chips Types.
Fractal Iterations – Controls the number of fractal iterations. For more details, please see the Fractal Iterations examples below.
Fractal Roughness – Controls the roughness of the fractal. A value of 0.0 is very rough and a value of 1.0 is very smooth, which negates the fractal. For more details, please see the Fractal Roughness examples below.
Color Tweaks
Mult – Specifies a strength multiplier for the texture color.
Invert – When enabled, inverts the resulting texture color.
Alpha Tweaks
Source – Specifies where the alpha channel is drawn from.
Invert – When enabled and Invert from Color Tweaks is also enabled, the resulting texture alpha will be inverted as well.
Placement
Placement Type – Specifies the way the valid portion of the texture is applied.
Tile V – Enables vertical tiling.
UV Noise
Enabled – Enables noise for the texture.
Anchor
exampleCellularSize
exampleCellularSize
Example: Size
width20%
width60%
Image slider
Panel
borderStylenone
Dots Size: 0.05
Panel
borderStylenone
 Dots Size: 0.1
Panel
borderStylenone
Dots Size: 0.2
Panel
borderStylenone
 Chips Size: 0.2
Panel
borderStylenone
Chips Size: 0.35
Panel
borderStylenone
 Chips Size: 0.5
Panel
borderStylenone
Cells Size: 0.1
Panel
borderStylenone
Cells Size: 0.2
Panel
borderStylenone
Cells Size: 0.5
Panel
borderStylenone
Chess Cells Size: 0.1
Panel
borderStylenone
Chess Cells Size: 0.2
Panel
borderStylenone
Chess Cells Size: 0.5
Panel
borderStylenone
 Plasma Size: 0.05
Panel
borderStylenone
Plasma Size: 0.07
Panel
borderStylenone
Plasma Size: 0.2
width20%
Anchor
exampleSpread
exampleSpread
Example: Spread
width20%
width60%
Image slider
Panel
borderStylenone
Dots Spread: 0.5
Panel
borderStylenone
Dots Spread: 1.0
Panel
borderStylenone
 Dots Spread: 1.5
Panel
borderStylenone
Chips Spread: 0.5
Panel
borderStylenone
Chips Spread: 1.0
Panel
borderStylenone
 Chips Spread: 2.0
Panel
borderStylenone
 Cells Spread: 0.1
Panel
borderStylenone
 Cells Spread: 0.5
Panel
borderStylenone
 Cells Spread: 1.0
Panel
borderStylenone
Chess Cells Spread: 0.1
Panel
borderStylenone
Chess Cells Spread: 0.5
Panel
borderStylenone
 Chess Cells Spread: 0.9
Panel
borderStylenone
 Plasma Spread: 1.0
Panel
borderStylenone
Plasma Spread: 3.0
Panel
borderStylenone
Plasma Spread: 5.0
width20%
Anchor
exampleDensity
exampleDensity
Example: Density
width20%
width60%
Image slider
Panel
borderStylenone
Dots Density: 0.1
Panel
borderStylenone
 Dots Density: 0.25
Panel
borderStylenone
Dots Density: 1.0
Panel
borderStylenone
Chips Density: 0.25
Panel
borderStylenone
Chips Density: 0.7
Panel
borderStylenone
Chips Density: 1.5
Panel
borderStylenone
Cells Density: 0.15
Panel
borderStylenone
Cells Density: 0.25
Panel
borderStylenone
 Cells Density: 0.5
Panel
borderStylenone
Chess Cells Density: 0.15
Panel
borderStylenone
 Chess Cells Density: 0.25
Panel
borderStylenone
Chess Cells Density: 0.5
Panel
borderStylenone
Plasma Density: 0.5
Panel
borderStylenone
 Plasma Density: 1.0
Panel
borderStylenone
Plasma Density: 2.0
width20%
Anchor
exampleLow
exampleLow
Example: Low
width5%
width45%
The Dots examples below use Size: 0.25, Spread: 0.5, and Density: 1.5. The Edge Color is blue for visual clarity
Image slider
Panel
borderStylenone
Dots Low: 0.0
Panel
borderStylenone
Dots Low: 0.5
Panel
borderStylenone
Dots Low: 1.0
width45%
The Chips examples below use Size: 1.0, Spread: 0.75, and Density: 3.0. The Edge Color is blue for visual clarity.
Image slider
Panel
borderStylenone
Chips Low: 0.0
Panel
borderStylenone
Chips Low: 0.5
Panel
borderStylenone
Chips Low: 0.9
width5%
Anchor
exampleMiddle
exampleMiddle
Example: Middle
width5%
width45%
The Dots examples below use Size: 0.25, Spread: 0.5, and Density: 1.5. The Edge Color is blue for visual clarity.
Image slider
Panel
borderStylenone
Dots Middle: 0.0
Panel
borderStylenone
Dots Middle: 0.5
Panel
borderStylenone
Dots Middle: 1.0
width45%
Image slider
Panel
borderStylenone
Chips Middle: 0.0
Panel
borderStylenone
Chips Middle: 0.5
Panel
borderStylenone
Chips Middle: 1.0
width5%
Anchor
exampleHigh
exampleHigh
Example: High
Anchor
exampleFractalIterations
Example: Fractal Iterations
Anchor
exampleFractalRoughness
Example: Fractal Roughness
The Dots examples below use Size: 0.25, Spread: 0.5, Density: 1.5, and Fractal Iterations: 3.0.
