width50%
There are a number of different materials for use with V-Ray for Houdini. These materials are quite versatile and each can be used in a number of ways to achieve different looks as needed from simulating simple surface properties like plastics and metals, to simulating complex uses such as translucent objects, subsurface materials such as skin, and even light emitting objects.
Some basic information on each material can be found below, but for more details, please see the dedicated pages for each one.
Note: Standard Houdini materials are not supported by V-Ray!
width5%
width45%
 Image Added
UI Paths
width5%
width45%
||shop mat Network|| > Material > V-Ray Material node > V-Ray > Material sub-menu
Image Modified
width45%
 ||mat out Network|| > V-Ray Render Elements node > V-Ray > Material sub-menu
width5%
V-Ray Material Builder Node
The V-Ray Material Builder (vrayMaterialBuilder) node is a container that allows you to create V-Ray materials, textures, and additional V-Ray nodes.
Image Removed
By default, it creates a V-Ray Material (BRDFVRayMtl) connected to a V-Ray Material Output node. For additional information, see the V-Ray Material Builder page.
Image Removed
List of V-Ray BRDF Materials
width5%
width30%
Hair
width30%
Image Modified
Light
Hair 3
width30%
Image Modified
Override
Light
width5%
width5%
width30%
Image ModifiedHair 3
Override
width30%
Image Modified
VRscansSkin
width30%
Image Modified Skin
SSS
width5%
width5%
width30%
Image ModifiedSSS
Two Sided
width30%
V-Ray alSurface
width30%
V-Ray Material
width5%
width5%
width30%
VRayMtlOSL
V-Ray OSL Material
Image Removed
Two Sided
width30%
Image Modified
VRmat
V-Ray Point Particle
width30%
Image Modified
Wrapper
V-Ray Stochastic Flakes
width5%
width5%
width45%30%
VRayToonMtl
V-Ray Toon Material
width30%
Image Added
VRmat
width30%
Image Added
VRscans
VRayMtlOSL
V-Ray OSL Material
width45%5%
width5%
width30%
width30%
Image Added
Wrapper
width30%
width5%
List of Additional V-Ray Material Nodes
Render Stats
Fancy Bullets
typecircle
