width33%
||mat Network|| > V-Ray> Procedural Texture > V-Ray Celluar
width33%
 ||out Network|| > V-Ray Render Elements node > V-Ray > Procedural Texture > V-Ray Cellular
width33%
Alpha – Alpha channel is drawn from the texture.
Color Intensity / Luminance Color
– Alpha is generated from pixel intensity.
Opaque
– Alpha channel is fully opaque.
Use – Differentiate between textures exported from different applications. You can choose between Color Intensity (3ds Max) and Color Luminance (Maya).
Mult – Specifies a multiplier for the texture alpha.
