This This page provides information on the V-Ray Falloff texture.
Section | |||||||||||||||
Node
The TexGrid node provides inputs for controlling various texture properties. They correspond to parameters in the section below.
Type – Specifies the type of falloff:
Blend Input – Specifies the final blending amount that will be taken is taken from the texture.
Use Blend Curve – Enables the Blend Curve for controlling the blending.
Alpha – Alpha channel is drawn from the texture.
Color Intensity / Luminance Color – Alpha is generated from pixel intensity.
Opaque – Alpha channel is fully opaque.
Use – Differentiate between textures exported from different applications. You can choose between Color Intensity (3ds Max) and Color Luminance (Maya).
Mult – Specifies a multiplier for the texture alpha.
Invert – When enabled and Invert from Color Tweaks is also enabled, the resulting texture alpha will be inverted is inverted as well.
Anchor | ||||
