Section | |||||||||||||||||
Node
The TexFresnel node provides inputs for controlling various texture properties. They correspond to parameters in the section below.
Refract IOR – Specifies the refraction index of refraction for the underlying surface. This is ignored if the surface has a volume shader (the volume IOR will be used is used instead).
Contribute to Fresnel IOR Render Element – When enabled, the V-Ray Fresnel Texture will contribute contributes to the Fresne IOR Render Element.
