width33%
||mat Network|| > V-Ray> Utility Texture > V-Ray Invert
width33%
||shop out Network|| > V-Ray Material > Render Elements node > V-Ray> Ray > Utility Texture > V-Ray Ray Invert
width33%
Node
The V-Ray TexInvert node provides inputs that correspond to the parameters in the section below.
Image Added
Texture – Specifies the texture that will have has its colors inverted.
Invert Alpha – When enabled, the texture alpha will be is inverted as well.
