This page contains information about the V-Ray Invert Texture node.
The V-Ray TexInvert node is a utility used to invert texture colors.
UI Paths
||mat Network|| > V-Ray> Texture > V-Ray Invert
||shop Network|| > V-Ray Material > V-Ray> Texture > V-Ray Invert
Texture – Specifies the texture that will have its colors inverted.
Invert Alpha – When enabled, the texture alpha will be inverted as well.
