width33%
||mat Network|| > V-Ray> File Texture > V-Ray OSL Texture
width33%
 ||shop out Network|| > V-Ray Material > Render Elements node > V-Ray> Ray > File Texture > V-Ray Ray OSL Texture
width33%
Node
The TexOSL node provides inputs that correspond to parameters in the section below.
OSL Source – Determines how the OSL code will be is drawn.
Inline OSL
File path (.oso/.osl)
