This page contains information about the V-Ray OSL Texture.
The V-Ray OSL Texture map can be used to load Open Shading Language OSL shader code files (.osl) or OSL object code files (.oso) and render them directly with V-Ray. It can be used with shaders that have simple color and float output parameters. These parameters are considered respectively as texture RGB and alpha outputs.
For more on OSL in general, see the Github reference.
UI Paths
||mat Network|| > V-Ray> File Texture > V-Ray OSL Texture
 ||out Network|| > V-Ray Render Elements node > V-Ray > File Texture > V-Ray OSL Texture
Node
The TexOSL node provides inputs that correspond to parameters in the section below.
OSL Code
OSL Source – Determines how the OSL code is drawn.
Inline OSL
File path (.oso/.osl)
OSL Code A space for manual insertion of an OSL code.
Path to .oso/.osl file Specifies the .osl or .oso file which contains the shader (object) code.
Color & Alpha Tweaks
These rollouts are the standard V-Ray for Houdini texture rollouts.
  • The VRayTexOSL texture automatically compiles OSL shaders to object code (OSO format) upon shader selection. No following compilations occur (even at render events). If the loaded OSL shader is modified click the Recreate attributes button for your changes to take effect.
  • An OSL compiler that translates *.osl files to *.oso files can be found in the tools subdirectory of V-Ray's root installation folder.
References
