© Taichi Kobayashi
This page provides details on the settings available for the OSL Material in V-Ray.
The VRayMtlOSL material can be used to load OSL shader code files (.osl) or OSL object code files (.oso) and render them directly with V-Ray.
OSL Source – Specifies whether the OSL shader code is inserted inline or loaded through a file.
Inline OSL – The OSL shader code is inserted inline.
File path (.oso/.osl) – The OSL shader code is loaded through a file.
Path to .oso/.osl file – Specifies the path to the OSL shader code file.
References
