changes.mady.by.user Developer
Saved on Jul 11, 2014
Saved on Jul 15, 2014
Syntax: AddVrayMtl()
Adds a new V-Ray Material to the scene and applies it to the selection if this is possible.
Syntax: AddVRayTwoSidedMtl()
Adds a new V-Ray Two Sided Material to the scene and applies it to the selection if this is possible.
Syntax: AddVRayBlendMtl()
Adds a new V-Ray Blend Material to the scene and applies it to the selection if this is possible.
Syntax: AddVRayLightMtl()
Adds a new V-Ray Light Material to the scene and applies it to the selection if this is possible.
Syntax: AddVRayOverrideMtl()
Adds a new V-Ray Override Material to the scene and applies it to the selection if this is possible.
Syntax: AddVRayWrapperMtl()
Adds a new V-Ray Material Wrapper to the scene and applies it to the selection if this is possible.
Syntax: AddVRayFastSSS2Mtl()
Adds a new V-Ray FastSSS2 Material to the scene and applies it to the selection if this is possible.
Syntax: AddVRayCarPaintMtl()
Adds a new V-Ray Car Paint Material to the scene and applies it to the selection if this is possible.
Syntax: AddVRayHairMtl()
Adds a new V-Ray Hair Material to the scene and applies it to the selection if this is possible.
Syntax: AddVRaySimbiontMtl()
Adds a new V-Ray Simbiont Material to the scene and applies it to the selection if this is possible.
Syntax: AddVRaySkinMtl()
Adds a new V-Ray Skin Material to the scene and applies it to the selection if this is possible.
Adds a new V-Ray EMFluid emFluid Volume Shader to the scene and applies it to the selection if this is possible.
Syntax: AddVRayDisplacementProperty()
Applies a VRayDisplacementProperty to the objects from the selection list.
Syntax: AddVRayMeshLightProperty()
Applies a VRayMeshLightProperty to the objects from the selection list.
Syntax: AddVRayObjectProperty()
Applies a VRayObjectProperty to the objects from the selection list.
Syntax: AddVRayRenderMapProperty()
Applies a VRayRenderMapProperty to the objects from the selection list.
Note: Note that VRayRenderMap property is not supported for Softimage versions prior to 2011.
Applies a VRayRenderMaskProperty to the objects from the selection list.
