« Previous Version 2 Current »
This is the list of supported by V-Ray custom commands divided in the following categories :
Materials
AddVrayMtl
Syntax: AddVrayMtl()
Adds a new V-Ray Material to the scene and applies it to the selection if this is possible.
AddVRayTwoSidedMtl
Syntax: AddVRayTwoSidedMtl()
Adds a new V-Ray Two Sided Material to the scene and applies it to the selection if this is possible.
AddVRayBlendMtl
Syntax: AddVRayBlendMtl()
Adds a new V-Ray Blend Material to the scene and applies it to the selection if this is possible.
AddVRayLightMtl
Syntax: AddVRayLightMtl()
Adds a new V-Ray Light Material to the scene and applies it to the selection if this is possible.
AddVRayOverrideMtl
Syntax: AddVRayOverrideMtl()
Adds a new V-Ray Override Material to the scene and applies it to the selection if this is possible.
AddVRayWrapperMtl
Syntax: AddVRayWrapperMtl()
Adds a new V-Ray Material Wrapper to the scene and applies it to the selection if this is possible.
AddVRayFastSSS2Mtl
Syntax: AddVRayFastSSS2Mtl()
Adds a new V-Ray FastSSS2 Material to the scene and applies it to the selection if this is possible.
AddVRayCarPaintMtl
Syntax: AddVRayCarPaintMtl()
Adds a new V-Ray Car Paint Material to the scene and applies it to the selection if this is possible.
AddVRayHairMtl
Syntax: AddVRayHairMtl()
Adds a new V-Ray Hair Material to the scene and applies it to the selection if this is possible.
AddVRaySimbiontMtl
Syntax: AddVRaySimbiontMtl()
Adds a new V-Ray Simbiont Material to the scene and applies it to the selection if this is possible.
AddVRaySkinMtl
Syntax: AddVRaySkinMtl()
Adds a new V-Ray Skin Material to the scene and applies it to the selection if this is possible.
AddVRayEMFluidVolumeShader
Syntax: AddVRayEMFluidVolumeShader()
Adds a new V-Ray emFluid Volume Shader to the scene and applies it to the selection if this is possible.
Lights
AddVRaySun
Syntax: AddVRaySun()
Adds а VRaySun node to the scene.
AddVRayIESLight
Syntax: AddVRayIESLight()
Adds а V-Ray IES light to the scene.
AddVRayLight
Syntax: AddVRayLight()
Adds а VRayLight to the scene.
Properties
AddVRayDisplacementProperty
Syntax: AddVRayDisplacementProperty()
Applies a VRayDisplacementProperty to the objects from the selection list.
AddVRayMeshLightProperty
Syntax: AddVRayMeshLightProperty()
Applies a VRayMeshLightProperty to the objects from the selection list.
AddVRayObjectProperty
Syntax: AddVRayObjectProperty()
Applies a VRayObjectProperty to the objects from the selection list.
AddVRayRenderMapProperty
Syntax: AddVRayRenderMapProperty()
Applies a VRayRenderMapProperty to the objects from the selection list.
Note: Note that VRayRenderMap property is not supported for Softimage versions prior to 2011.
AddVRayRenderMaskProperty
Applies a VRayRenderMaskProperty to the objects from the selection list.
V-RayProxy commands
ImportVRayMesh
Imports a VRayProxy object from an existing mesh file. Currently VRay Mesh file (.vrmesh) and Alembic(.abc) file are allowed as an input mesh file.
Syntax: ImportVRayMesh(meshFilename, displayAs, isAnimated)
OptionDescription
meshFileName
The full path filename of the mesh file (tokens are supported).
displayAs
Specifies the display mode of the imported mesh.
0 - the proxy is displayed as its bounding box.
1 - the information in the mesh file is used to generate a simplified preview (proxy preview representation) of the geometry.
Default value: 1
isAnimated
Specifies whether the proxy is animated.
Default value: true
ExportVRayMesh
Exports the selected polymesh objects to .vrmesh file(s).
Syntax: ExportVRayMesh(saveIn, fileName, exportType, bakeTransform, groupType, overwrite, animOn, animType, startFrame, endFrame, velocityOn, velocityIntervalStart, velocityIntervalEnd, shouldCreateProxy, previewFaces)
OptionsDescription
saveIn
This is the directory where the mesh file(s) will be created (tokens are supported).
Default value: current project's location
fileNameUsed only when exporting all selected geometry objects into a single file (i.e. when exportType=0). This option specifies the name of the output .vrmesh file. You don't need to specify a path - the folder from saveIn will be used.
exportType
Determines whether the selected meshes should be exported to separate files or all of them into 1 file.
0 -  exports all selected objects in a single .vrmesh file. This option also stores the transformations of the selected objects;
1 -  exports each selected object in a separate .vrmesh file. The name of each file is derived from the name of the corresponding Softimage node. The transformation of an object is not included in its mesh file unless specified via bakeTransform;
Default value: 0
bakeTransform
Specifies whether objects transformations should be written into the vrmesh file(s)
Default value: true
groupType
Specifies how faces will be grouped according to the materials IDs.
0 - the selected faces that have the same material will be assigned with the same Material ID;
1- groups faces according to mapping to existing clusters. When the faces in the geometry have been previously divided into clusters, this options assigns the same material ID to the faces in each cluster regardless of the material assigned to individual faces;
Default value: 0.
overwrite
When turned on - will automatically overwrite any existing .vrmesh files.
Default value: true
animOn
Sprecifies whether animation be exported as well.
Default value: false
animType
Determines the animation interval for export.
0 - exports all the frames from the animation timeline;
1 - manually specify the frame range for the animation export by using the startFrame and endFrame parameters;
Default value: 0
startFrame
Specifies the start animation frame when using explicit range (animType=1).
Default value: 0
endFrame
Specifies the end animation frame when using explicit range (animType=1).
Default value: 10
velocityOn
If specified(animOn=true and velocityOn=true), vertex velocity is also exported. This enables motion blur and smooth interpolation of the resulting animated proxies. The time samples within a frame for computing the velocity are specified with the velocityIntervalStart and velocityIntervalEnd options.
Default value: true
A value between 0.0 and 1.0 with the time position within a frame for the initial vertex positions.
Default value: 0.0
velocityIntervalEnd
A value between 0.0 and 1.0 with the time position within a frame for the ending vertex positions.
Default value: 0.05
shouldCreateProxy
When this is turned on - after successful export, the original geometry objects will be replaced with proxy/proxies.
Default value: true
previewFaces
Specifies the maximum number of faces that will be used to show a preview of the proxy in the viewport.
Default value: 10000
Materials import
ImportVrsceneMaterial
Imports materials from a .vrscene file into the scene.
Syntax: ImportVrsceneMaterial(vrsceneFileName)
  • vrsceneFileName - the full path filename of the .vrscene file (token strings are supported);
VRayPhysicalCamera
AddVRayPhysicalCamera
Syntax: AddVRayPhysicalCamera()
Adds а V-Ray Physical Camera object to in the scene.
Geometric objects
AddVRayPlane
Syntax: AddVRayPlane()
Adds a VRayPlane object in the scene.
Miscellaneous commands
VRaySetHelperFolderLocation
Sets a new location of the helper folder, where VRay render state files are kept. The command should be invoked prior to rendering and will keep the record for the new location for as long as the VRay .xsiaddon remains loaded. Once the command is executed, for subsequent render calls VRay will save the VRay VFB history (vfbhistory.xml) to the specified directory. On a new scene (created after executing the command), this will also modify the default locations for the new scene's irradiance map, lightcache, photonmap, VRay logs (like vray_log.txt) etc. files. However, on existing scenes, these file paths are already stored as part of the Renderer settings, so calling the custom command will not be enough. If you want to redirect these files, you also need to change those properties.
Syntax: VRaySetHelperFolderLocation(folder)
  • folder - the new directory name where VRay render state files will be stored (path tokens are supported). The Default value is [Project Path]/Vray1" which is the Vray1 helper folder nested under the current project structure.
ClearVRayGeometryCache
Syntax: ClearVRayGeometryCache()
Forces the clearing of any cached geometry for the currently open scene.The command might fail if a lengthy render process is in progress and geometry caches cannot be accessed.
VRaySaveVFB
Saves the VRay VFB buffer to an image file.
Syntax: VRaySaveVFB(path)
  • path - the full path filename of the image file where the VRay VFB buffer will be written (tokens are supported).
VRayRefreshProxyPreview
Rebuilds the proxy preview mesh for the current frame.
Syntax : VRayRefreshProxyPreview(objname) - updates the preview mesh for objname
Syntax 2: VRayRefreshProxyPreview() - updates the preview for the selected object, or for all objects if selection is empty
